US Tiger Woods, Xbox Live - Silly question
Discussion in 'Xbox Forums' started by jerkyboy, Oct 9, 2004.
  1. jerkyboy
    jerkyboy
    This may sound like a very silly idea, but would the NTSC version of Tiger Woods 2005 work on UK Xbox Live.
    As the Live features of the UK version were dropped, it would be great if it did work.
    Has anyone tried it ?.
    Also does any version, UK of NTSC support 480p progressive scan.
  2. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    The PAL version of TW2005 doesn't work with the dashboard set to NTSC so that rules out 480p.
    Don't see why the NTSC version on an NTSC machine wouldn't be live playable in the UK. I only say NTSC machine because if the PAL doesn't work on NTSC then no doubt EA have made the NTSC incompatible with PAL machines too. :mad:
