US Region1 DVD Players
Discussion in 'Blu-ray & DVD Players & Recorders' started by RM, Feb 27, 2001.
  1. RM
    RM
    Unfortunately my Toshiba 3107 multi region player will not play discs with RCE. As I am visiting the US this year I am considering buying a US Toshiba R1 player. Does anyone know where I can source a "step down" mains transformer and are these "safe" to be connected to the power supply for prolonged periods.
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,484
    Newcastle
    +295
    You can get them from the likes of Tandy & Maplin.
    I've had mine plugged in for two and a half years now without incident.
    Cheers,
    Liam
    "Do you hear that, Mr. Anderson? That is the sound of inevitability."
