US PS2/TV Compatibility question:
Discussion in 'General TV Discussions Forum' started by Samuel, Mar 23, 2003.
  1. Samuel
    Samuel
    I'm thinking of getting a US PS2 to play certain games, but I have no idea if my TV will be compatible with it because I've lost the instructions. My TV is a Panasonic TX-21AD2, it has 2 SCART sockets and a three pin AV socket (Red, white, yellow), it is also capable of displaying 60Hz mode in games. That's all the relevant info I can think of concerning the TV, so can anyone help? It would be greatly appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I would guess that your TV would be NTSC compatible, but run a search in google for the model number and on the panny site as they have the user manuals in .pdf for most things on there.
  3. Samuel
    Samuel
    Thanks very much.
  4. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    I have a PAL PS2 and play NTSC games with no problems on my PAL SONY TV.
    I just had to purchase an RGB scart lead and then NTSC games played fine otherwise they are in B&W.
    Your have to get a Downconverter for your Power Supply if you choose a US Unit.
    Dal
  5. Samuel
    Samuel
    That's great, cheers mate.
