US PS2 Compatibility question:
Discussion in 'Playstation Forums' started by Samuel, Mar 23, 2003.
  1. Samuel
    Samuel
    I'm thinking about getting a US PS2 and I don't know if my TV will properly display the picture. Here are a few of my TV's specs:
    Power source: 220-240 50 Hz A.M. (I've played games on it in 60 Hz mode and it seems fine)
    Receiving Systems/band name: PAL 1
    PAL 525/60 Playback NTSC tape from PAL Video recorders. M.NTSC Playback from M.NTSC Video recorders. NTSC (AV input only) Playback from NTSC Video recorders.
    AV1- 21 pin terminal- Audio / Video in / out, RGB in.
    AV2- 21 pin terminal- Audio / Video in / out, S-Video in.
    2 x RCA Audio Monitor Out.
    AV3- 2 x RCA Audio in, 1 x RCA Video in.
    I hope that enough info to tell. Any help will be greatly appreciated.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Yes, it will. Get an RGB Scart cable and it will look stunning.
    Neil.
  3. Samuel
    Samuel
    Thanks mate.
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    NP, just make sure you plug it into the RGB port AV1.
    Neil.
  5. Samuel
    Samuel
    OK, so the others won't work then?
  6. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    They will but RGB will give you a picture that is far better than composite or svideo
    Neil.
  7. Samuel
    Samuel
    Thanks again.
