US Plasma question
Discussion in 'Plasma TVs' started by Mag9, Nov 29, 2003.
  1. Mag9
    Mag9
    I am currently working in the US for 3 years and about to buy a TV. I am aware of the technolgy difference in CRTs but was told by the local salesman that I would be able to use a US plasma back in the UK when I return, subject to using a transformer to step down the power source from 220v to 110v (which should be relatively easy to do). I would be grateful if someone could confirm whether this is true and whether it would also be true if the plasma had an in-built tuner (ie can these be switched off so that it becomes a pure monitor)?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,592
    3
    North Yorkshire
    +280
    Using a US model plasma in the UK shouldn't be a problem using a step-down voltage converter. Most plasmas can handle 120 or 240 volts anyway, so you may not even need a converter. Plasmas don't normally have built-in tuners, but some do have separate media receivers. For example, the new Pioneer 4340HD comes with a receiver box that has a hi-def tuner in addition to a standard NTSC tuner. Of course, these won't be of much use in the UK, unless we adopt the HD standard in the meantime - which is fairly unlikely to happen anytime soon. Hope this helps.
    Steve
  3. Claus
    Claus
    No problem buying a Plasma in the states.
    As long as it plays back PAL signals(most do, but check it out!) there's no problem. Using a transformer is no problem.
    Some plasma screens has built in tuners. I recommend not buying one of those. I weakens the signal and you can't bypass the tuner, using it just as a monitor.
    Go for a Pio 4340 or a Panny 6!
    C
  4. Arsenal
    Arsenal
    Mar 25, 2002
    232
    London
    Heh, Claus didn't you just tell him not to buy a Pio 4340 with the bit about the built in tuner? ;)
  5. Dutch
    Dutch
    Dec 5, 2002
    2,592
    3
    North Yorkshire
    +280
    Is a separate tuner box classed as built-in?
    Steve
  6. Claus
    Claus
    The Pio 434 input signal is not going through the tuner. It goes digitally direct to the screen! HDMI.
    C
  7. Arsenal
    Arsenal
    Mar 25, 2002
    232
    London
    the HDMI input is in the Media Receiver with the tuner though is it not? Ah well.. as you can see from my signature, its not putting me off any :)
  8. Claus
    Claus
    Yes, the HDMI input is on the tuner. But the DVD input or any other device is not going through the "tuner" part of the Media box, as in i.e Panny PA20.
    The signal is going directly(if chosen) to the plasma(digitally).
    C
  9. Mag9
    Mag9
    Many thanks for your replies, they were the reassurance I was looking for - always difficult to know whether the sales guys are spinning you a line. I will now hit the Thanksgiving sales! Will probably go for the Panny or Philips. The Pioneer is a couple of grand (US$) beyond my budget.
  10. lloydde
    lloydde
    Nov 10, 2003
    10
    I am about to buy the Panny TH-37PW6 from the States as it is the pefect size for my room and not available in the UK. The current exchange rate may make it cheaper than buying the UK's closest equivalent.
    Will soon be dealing with these conversion issues.
    Having looked at the technical specifications of the power unit I am hoping it is compatable9Switchable) with the UK power supply. If not I will find the cheapest, smallest but adequate power transformer available.
    My plan is to use the component input supplied to connect VCR, Sky+ and DVD using a 3 scart switcher and a scart to component converter.
    Let me know if you want to know how I got on.
  11. jfraser
    jfraser
    Mag 9
    Be VERY careful about which Plasma you buy in the US.....I'm in the same position as you, and I nearly bought a Pio 5040HD....these units are NTSC at bought the tuner AND panel level (I confirmed this with PIO USA...they will not work in the UK)....this is also the case with the panny consumer unit.....You need to buy the commercial models (don't have seperate media units)...They will clearly state that they are multi standard.
    I ended up having too buy a 504HDE from the UK
  12. jfraser
    jfraser
    sorry for the typo....should read NTSC at BOTH the tuner and panel level
  13. evilrkd
    evilrkd
  14. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
