US Monster DVI Cables...Do They Work In The UK?
Discussion in 'Cables & Switches' started by swanny78, Oct 25, 2005.
  1. swanny78
    swanny78
    Apr 19, 2005
    1,041
    48
    Matlock
    +66
    Ive seen a bargain on ebay for a DVI400 DVI cable it is been shipped from the US. Im assuming that US DVI cables are the same as UK ones, im under the impression they are universal....just though i'd check before I purchase.
    Also got some QED S.A.BI-WIRE cable but no longer have bi-wirable speakers. Am I able to pull the cable apart to create a 2 dual core cables. Assuming of course the protective jacket stays in one peice which I think it will.
    Advice on both much appriciated.... :thumbsup:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,993
    The Borders
    +3,600
    Hello swanny78
    A DVI cable from the US will work just as well as a DVI cable from a UK manufacturer - chances are they both came from the Far East anyway :)
    Your plan to 'split' a Bi-Wire cable sounds fine too - make sure you don't damage the outer sheathing mind.
    Best regards
    Joe
  3. swanny78
    swanny78
    Apr 19, 2005
    1,041
    48
    Matlock
    +66
    just what I wanted to hear....cheers.
