I
IanMerseyside
I notice that the BBC HD channel are showing extensive coverage and according to the info bar it is to be in HD. Is this correct?
I notice that the BBC HD channel are showing extensive coverage and according to the info bar it is to be in HD. Is this correct?![]()
Will certainly give it a look even though I find golf so![]()
If its up to the normal BBCHD standard it should be great for you guys who like golf.
I've been lucky enough to play at some of the best courses in the UK and when your stood on the 18th tee at The Brabazonit makes you realise you how good the top players really are.
For any non golfers out there, go and have a try at your local driving range and then watch some golf on tv and you'll realise what a tremendously difficult sport it is.
Golf was well defined some time ago as "A long walk punctuated by disappointments."Yeah agree with this, but playing it and watching it are 2 different things. Its one of those sports that you either love or hate I suppose.
I hope what you're looking for isn't the same.
And "A good walk spoiled!"
I'm off to South Caroliner for ten days of it in less than a fortnights time!![]()
I shall be taking a big suitcase in case I see anything irresistable in the gadget shops!
ATB
Max
You're not going to Myrtle Beach by any chance are you? There are so many mini golf parks there that I had a mental image of you putting through a miniature windmill!
Love that spelling 'Caroliner' BTW.![]()
Yes, Myrtle Beach it is! It's a dirty job and someone has to do it!![]()
Fifth visit there for me! Twenty guys on tour!
Sorry about the spelling!It was a Freudian slip, I'm in the garage business and 'Caroliner' is a body jig!
ATB
Max
Max
Lots of fast movement actually, every time the camera follows a ball off the tee.We will be giving it a watch here and there just to see what it looks like in HD, should look good as there is not a lot of fast movement, should look better then soccer.
ATB
Max
Just watched last nights preview programme on BBBHD. Noticed some very bad compression artifacts on the horizontal lines on GL's shirt and on the vertical balustrades on the building verandas.
And more problems with PQ when a fast moving ball passes across a detailed background (eg trees), the ball seems to flicker and skip frames.Just watched last nights preview programme on BBBHD. Noticed some very bad compression artifacts on the horizontal lines on GL's shirt and on the vertical balustrades on the building verandas.
I don't get it, the programme starts at 9pm, not 1pm? We're missing loads of golf, we'll miss most of Tiger's round and many other golfers!
Jake
