US Gamecube
Discussion in 'General Video Gaming Chat' started by H4r7y, Dec 14, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    anyone tell me the pro's ans con's of getting a us gamecube?
    ive been told that because ive not got a 60hz tv that us games will only run in black and white. true?
    or will getting a freeloader sort all this out.
    ive found a uk site selling these things for £29 delivered so its a decent price as long as all works ok.
    cheers
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    where ??
    I doubt freeloader will change the video ouput.. does your tv not support PAL 60 at least
    Matt
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    yeah it does do pal60, but i was told that that wont work in colour either.
  4. buzlightyear
    buzlightyear
    Oct 8, 2002
    946
    46
    London
    +116
    I have a US/Jap cube and when using the freeloader it plays in Black and white when trying to play UK games (fine on US games) (50/60hz TV). Mrs Buzz has a UK cube and when using Freeloader on her display (50hz only) it plays in Black and white, but was ok when on a tv supporting 60hz. Not sure if this helps you in anyway but confirms you need 60hz to play US games. For £30 its not the end of the world if it dont work
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    no, but i dont really fancy playing games in black and white though, id rather just get hold of a uk cube instead.
    im a bit confused though about what your actually saying.
    my tv supports pal60, but not ntsc playback. will the us cube still work fine through pal60?
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    +119
    So care to share where they are selling for £29 ?
    Problem I think it that the GC does not do RGB (though custom cables which frigged it could be bought)
    I used to run my PS way back in the day on a tv which took PAL60 and would play in colour from my jpn ps via a RGB cable. So it you had a US Gc + the RGB cable it should work.. but the cables cost about £50 as they are butchered Component cables. The standard UK rgb cables for the GC will not work..
    Hope that clears it up :)
    Matt
  7. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
  8. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    +119
    Must be going blind I cannot see any Gc stuff on that website ? :)
  9. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    +119
    Whoops found it :)
    BTw don;t forget to add VAT to the price.. they always leave it out :(
  10. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    yeah its about £29 all in
  11. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    anyone shed a bit more light on this one for me?
  12. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,772
    Bristol
    +6,377
    As far as I am aware the US Gamecube will only output a NTSC60hz signal, after all its a US model so there is no reason for it to do PAL. The UK Gamecube will output both PAL50hz for UK games and PAL60hz for the games that have the 60hz option. If you use Freeloader to play US games on a UK gamecube they will be output as PAL60hz.
    The Freeloader itself doesnt do anything to the video signal, it just allows you to play games from other regions on any region Gamecube, nothing more so if you get a US gamecube you will have to have a TV that can handle an NTSC60hz signal otherwise all you will get is a black and white picture on all games you play whether they are US or UK.
  13. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    cheers mate, got a little confoosed earlier.
