US Gamecube Step Down Converter
Discussion in 'General Video Gaming Chat' started by EmissarY, Dec 19, 2004.
  1. EmissarY
    EmissarY
    Can anyone tell me where the cheapest and quickest place is to get a step down transformer for my US Cube please?
    I see LikSang do them but I bought one from there and the plastic box around the transformer fell apart.
    Dont mind too muchg on price, I just need it quickly.
    Regards,
    EmissarY
  2. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    Can't you just buy a uk GC transformer? It doesn't matter what region a GC comes from, they are basically the same design. All need the same voltage/amperage whatever. The only difference is in the transformers. i.e. the UK version has to take it down from 240v, compared to 110v in the USA, but they take it down to the same voltage. In the same way you can use a UK SP charger on an imorted DS. Obviously if a console has an internal power supply, you'll need a stepdown converter as this can't be changed.
    Unless I'm wrong? does anyone know 100%?
