US cube
Discussion in 'General Video Gaming Chat' started by Shoka, Feb 21, 2003.
  1. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    What is the going price at the moment for a 2nd hand US cube, I'm after one but don't have any idea of what to offer, and dont want to be taken for a mug.
    Would I be taking the mickey if I ofered someone £80?
    Any ideas?
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    £80 for the machine only, 1 pad, stepdown and all leads is a more than fair price. At the end of the day an NTSC Cube, although superior (in my opinion), is not worth any more than a 2nd hand PAL Cube.
  3. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    Just another quick question.
    What audio output does the cube have?
  4. Sinzer
    Sinzer
    May 25, 2002
    5,789
    +1,107
    Errrr none :p
    It simply outputs through the AV out, so you either have to get a custom cable with the L/R channels split on it, or run it through a splitter into your amp.
    It uses DPL2 encoding in the games to create a stereo sound. Unfortunately no optical/digital outs.
  5. Sam
    Sam
    Nov 6, 2000
    320
    Surbiton
    +5
    Or use your TV's phono outputs to send the signal to the amp. :p
  6. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    As has been mentioned, the Cube outputs analogue stereo via it's Multi-Out. You can use an S-Video/L/R Phono from the Multi-Out and run the phono's to your Amp or you can use Composite/L/R Phono.
    Best of all, you can use the Component Cable from the Cube's DV-Out for Progressive (or Interlaced) gaming and use the Multi-Out for audio only, again straight to your AMP ot TV. Finally you can use a modified RGB Scart Cable with Audio L/R breakout built-in. Contact me if you require more information on the RGB Scart cable for NTSC Cubes.
  7. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    Its just for my room, so it will be running on a 21" tv Which unforunatly does not have any audio outs. So a scart witch splits off into 2 phonos would be cool (do these exist?)
  8. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Well, if your tv is S-Video compatible, you can use a Nintendo S-Video + Audio cable to Scart Plug adapter. Then just run the phono's to the Amp instead of the Scart adapter. If you need to/want to use RGB Scart with built-in breakout, then PM me. These are not cheap though. See the site in my sig for instructions on how to make one.
  9. Shoka
    Shoka
    Jan 10, 2002
    4,327
    Surrey
    +239
    That looks pretty easy :eek:
    Think I'll leave it and just have it running off the TV (when and if I get one)
  10. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    groundy,
    Just a quick question. I'll be using the DV-out for progressive scan via a component cable. I presume I'll need to use the standard lead (included) to take the L/R audio to my amp, leaving composite video "dangling". Alternatively do Nintendo make an audio only lead for this purpose?
    Thanks,
    bibooo
  11. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    You presume right :). No Audio only lead exists as far as I know so just leave the Composite Phono dangling or snip the Composite portion of the cable at the Multi-Out and cover with a bit of black tape.
  12. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    Thanks for the confirmation. I'm surprised there's not an "all in one" lead which can handle digital video and analogue audio (like the PS2 component cable).
    It just seems a bit of overkill to have two leads coming from the Gamecube, even the modded RGB scart lead has to use both DV and analogue out??
    It was all so simple in the days of the C64. :)
  13. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    The DV-Out and the Analogue Out are two seperate entities on the Cube. Audio is not connected to the Dv-Out in any way - just Video, and hence the need for two seperate cables. Probably improves video quality by doing it this way :).
