US and a European T32 tuner
Discussion in 'TAG McLaren Audio Owners' Forum' started by mlinhares, Jun 2, 2005.
  1. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    Can a US T32R tuner operate in Europe without a problem?
  2. roversd1
    roversd1
    just the voltage- 110v
    The FM tuning steps might be different, not sure if they had LW
  3. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    Apart from 110V, no difference. I know someone having US T32R in Europe.
  4. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    uuups, mark was faster.
  5. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Not so fast dudes! Apart from the points mentioned (tuning steps/ranges, mains voltage) it also has pre-emphasis of 75uS so will sound a bit dull in Europe. I suspect a little trip to IAG HQ could have it converted back to European spec though...
  6. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    Thanks guys.
    I already have one european version. An early one with serial number 70. Works like a charm. The only problem is that it is black and all my other Tag gear is silver (DVD32R, 250x3, 100x5 and DP) and it looks a little "out of place" in my rack.
    I have (had) the oportunity to buy a silver but it is US specification… I think I'll keep the one I have.
  7. Kevinc
    Kevinc
    Apr 6, 2005
    105
    California
    +14
    If you are talking about the silver US one on ebay.com that ended at 00.30 GMT I won the auction for it for $700, so if anyone knows anything bad about that particular unit that the seller didn't disclose to me please let me know ASAP! Specification is ideal for me here in California (where the radio is so lousy anyway that it's likely to be more decorative than anything else...).
    Pity the faceplates aren't easy for the user to change, otherwise I'd be delighted to swap it for your black one to match my AV32R and DVD32FLR... Oh well, at least my Bryston 4BSST is also silver...
