URLs for SCART pinout (particulary YUV)
Discussion in 'Cables & Switches' started by Bearded_Malc, May 10, 2005.
  1. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    Anyone suggest some good URLs for SCART pinout for DIY cables. I have the standard pinouts, google works well enough for those, but the toppy has the option to output YUV on scart. I'd guess that it uses the RGB pins but does it? And which is which?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    www.keene.co.uk sell scart to phono leads that are listed as being for RGsB or Component. Therefore the pins must be the same for both RGB & YUV.
    Mark.
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    As Marks says, it is the same pins as RGB.
    A link for you , just use pins 5,7,9,11,13 and 15 (you will not need a composite sync, as you are using component on the RGB pins) - easy.
    http://www.diyha.co.uk/electronics/scart.html
    Mark.
  4. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    I've tried it and it works out to be quite logical, as Mr Spock would say. I first wired it up for RGB then swapped plasma and toppy both to YUV. When I remove the composite lead for sync in RGB then it all worked. Before that the composite sync was making the picture green. I don't why, it should have just ignored it.
    Anyway the end result is for YUV just connect R pin on the scart to R connector on the plasma (plasma can take RGB on these connector too), same for G and B.
