Urgently need Neutrik Speakon Interconnect
Discussion in 'Cables & Switches' started by notlongnow, Feb 24, 2005.
  1. notlongnow
    notlongnow
    Does anyone know where I can get a neutrik speakon inter-connect made up to c. 15 meters in length? :lease:
    Mike :smashin:
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Is this for a REL sub?....if so,REL may well be able to help you in terms of replacement leads,and at a much higher price,Russ Andrews also used to sell one.
    An alternative is to make your own,if you're ok with a soldering iron,and Maplins sell all of the required bits if you look under Speakon on their website search.
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    I have made many if this is for a Rel sub.
    If you get stuck you know who to ask ;) much more reasonable than RA.
    Or DIY of course.
    Mark.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Apologies,Mark!...should have thought of you first...getting too late here!
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Mark
    Any possibility of a thinner version of your subwoofer cable?
  6. notlongnow
    notlongnow
    Thanks guys especially Mark for the contact details. I am having new surround set up fitted tomorrow so will discuss best solution given the options.
    Thanks again.
    Mike
