urgent!!
Discussion in 'Plasma TVs Forum' started by Garrymol, Feb 20, 2005.
  1. Garrymol
    Garrymol
    Feb 3, 2005
    43
    Wirral
    can someone with the knowledge please help,im going round in circles.
    the best way to connect my dmr e50 and samsung stb through a quintro box and then js vga to plasma converter.using scart leads,
    i can get it to work either e50 or stb but not both, pq is brilliant even on low settings.
    need to be able to record and play dvd cant do either at the moment???
    Thanks as always,Garry.
    Wife is on my back.:(
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Haven't a clue what you mean. Both E50 and STB together???????
    TV output scarts from E50 and STB need to be plugged into Quintro. Output scart into RGB 2 VGA.
    Do you mean that the output from the STB is routing through the E50 into VGA, via the scart link between the two?
    Please elaborate and I'm sure someone will help you further.
  3. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Can of course also run RGB scart from STB into 2nd scart on E50, then from scart 1 on E50 to RGB-2-VGA. This would give STB passed-thru when E50 is off, but E50 output when it is switched on/playing a DVD etc.
  4. Garrymol
    Garrymol
    Feb 3, 2005
    43
    Wirral
    thanks to av junkie for reply
