URGENT - Wall bracket for 42PV500
Discussion in 'Home Cinema Buying & Building' started by e_python, Jul 29, 2005.
  1. e_python
    e_python
    My new 42PV500 got delivered today ! :clap: :D :rotfl:
    Can someone recommend the best value for money bracket for it. :lease: :lease: :lease:
    I would quite like to install in over the weekend !!
    Look forward to hearing from you knowledgeable lot :lesson:
  2. bkny
    bkny
    May 11, 2005
    104
    16
    i bought mine from av-sales for £115 (tilting version,£99 for non-tiltiing) from the powerbuy section on this forum. No idea how good it is relative to others, but it got delivered the next day. I think you'd better order soon though as otherwise you won;t get it till Monday.
    I am also wall mounting my plasma this weekend, good luck dude
  3. e_python
    e_python
    Thanks BKNY. Any other suggestions guys?
  4. Dave
    Dave
    Jul 3, 2005
    11,483
    163
    +3,392
    You might still be able to get one from av sales for 100 quid including delivery for the tilting version.
    Great mount for the money but I think you'll struggle to get it for tomorrow.
  5. e_python
    e_python
    You are right. Weekend is probably not possible :rolleyes: :thumbsdow
    So I suppose I will have to wait till next weekend.
    But
    There are SO many different types I am all confused.
    Any comments on this one
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=11073&item=5792527402&rd=1
    I have never installed onne before so I want to the right one.
    My priorities
    1) As close to the wall as possible
    2) Easy to install
    3) Reasonable Price
    Please help me !
  6. greeny
    greeny
    Ok. With the PV500 due to its fat arse you can't get it that close to the wall anyway, and tilting is going to be difficult.
    I believe the powerbuy mount on this forum needs extra spaceers to overcome the arse situation.
    I do have the powerbuy mount and it's fine for the money, plus quick delivery when U order (in my case anyway)
    P.S - I'm not sure how the e-bay one is going to cope with the 'curved base' doesn't look as though it will to me!. But pictures can be deceiving.
  7. mickyd67
    mickyd67
    Jun 28, 2005
    581
    +14
    E Python - I have a bracket that I don't need. I have just ordered the Pedestal stand for mine from the sales forum on here.
    The one I have is the Panasonic version. It's brand new, and not used (my walls won't take the weight)
    If you'd be interested I'll check out the price, and put it on that forum if you like.
    Let me know - or PM me.
    Cheers.
  8. alscds
    alscds
    Can i just add a quick note! If the bracket you are using has a release button like the vogals range then make sure you put the release button at the top of the panel and not the bottom other wise you wont be able to get your hand up the back to press it should you need to get it off the wall
