galewis1
Established Member
I posted this on the REL subwoofer forum, but it won't hurt to ask here as well.
I have a REL Strata 5 on loan from a dealer, but I am having trouble setting up the high level connection to my AVR300 with the neutrik connector.
As I understand it, I should connect the red wire to the amplifier's right speaker red terminal, yellow to the amplifier's left speaker red terminal and black to either one of the black terminals.
However, I am using an channels 6 & 7 to bi-amp the front left and right channels. So I guess I'm right in saying that I'm running mono-blocks effectively?
Therefore, connections, again as I understand it, should be, red wire to the right monoblock red terminal, yellow wire to the left monoblock red terminal, and black wire to ground at, according to the manual, the pre-amplifier. I can't find any such point on the AVR300. The manual then states that if my pre-amplifier doesn't have a dedicated ground terminal, then to use of the chassis screws at the back of the pre-amplifier. Trouble is, my amp is integrated. Can I just attach to any one of the chassis screws on the back of the AVR300, or will this cause damage?
Thanks in advance for any prompt replies as I've got to get it back to the shop on Monday.
Gary
Gary
