Urgent Question !! Unicol bracket for 42" Panny Series 5
Discussion in 'Home Cinema Buying & Building' started by MontyUK, Jan 26, 2003.
  1. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Evening all,
    I've just put my Unicol wall-bracket up (the flat, non-tilt variety) in advance of my new panel arriving during the week . .. but realise I've made a fairly serious assumption . . .
    Can anyone confirm whether the centre of the bracket on the wall aligns to the centre of the panel (vertically) when it's hung on it ???? If not, whats's the difference, and which way ???!!!!
    Cheers,
    Monty.
  2. jmack
    jmack
    yes its dead centre the 42 plasma over hangs the side of the mount about 7inches on each side
    hope that helps
  3. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Is that 7 inches top and bottom you're talking about Jmack, or side to side ?
    Er, just realised my original post should have said 'horizontally' . . . it's the height I'm worried about :blush: Can you confirm for me height-wise ??
    Thanks in advance,
  4. jmack
    jmack
    7inches <-------------->
    about 3 1/2 from top and botom
    if you would like i will email u a piture from the side and top
  5. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    cheers JMack . . so it is even then, top and bottom, ie the centre of the unicol bracket is the same height as the centre of the screen ? That's all I'm worried about really . . .
    If so, that's my mind put at rest :)
    Thanks,
  6. jmack
    jmack
    i would not say excact even i would say about little diff
    maybe 3 1/2 inch at top 4 or 5 at bottom its hard for me to measure the bottom so going by eye
  7. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    ok, should be close enough hopefully . . . thanks for your help JMack.
