urgent problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by squirrely, Aug 23, 2005.
  1. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    hi all, i am in the middle of fitting a new 4R160L0 160gb maxtor hd in my sky plus and now have to switch the jumper to "cable select", as i am new to this sort of thing, can someone please tell me how to do this please. thank's :smashin:
  2. Moosh
    Moosh
    Sep 12, 2004
    2,002
    2
    Bristol
    +473
    On the back of the hard drive should be six pins, two rows of three pins and connecting two of these pins should be a jumper (a small plastic coated metal). Underneath your harddrive, near these pins or even on the label on top of your hard drive should be a drawing of this pins with the letters CS next to one column. This is the Cable Select option. Prize the jumper out and then connect it across the two CS pins.
    Your harddrive is not is cable select mode.
    Moosh
  3. JayCee
    JayCee
    Jan 20, 2004
    20,088
    Lanarkshire
    +1,914
    There is usually a small diagram of the jumper pins on the label of the HD or there will be a diagram packed with it.
    There are usually 3 choices....Master (MA) Slave (SL) and Cable Select (CS)....You need to put the jumper over the two pins marked CS.
  4. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    Thanks Folks :thumbsup: It is back together and working ok. The jumper was already set to cs as it happens.
  5. SeanT
    SeanT
    Jan 28, 2005
    6,125
    Coventry
    +371
    Who told you you were allowed to say that! :rotfl:
