URGENT: Problem with Sony Freeview Box
Discussion in 'Freeview & YouView' started by emile heskey, Jul 2, 2004.
  1. emile heskey
    emile heskey
    I have got a problem with my Sony Freeview Box VTX-D800U. Basically I've just bought it and when changing the TV output I selected YC (?) and now I can't get a picture at all!
    Can anyone help me get the picture back, or is there a way to reset the system?
    Thanks a lot... :)
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    have you tried powering the box down or holding the button on the box in for about 15 secs?. When I tried y/c I got a b/w picture so it was just a case of reselecting rgb
  3. carpfisher
    carpfisher
    On the set-top box, temporarily move the scart connector from the socket labelled "TV" to the one labelled "VCR", which should now connect to the TV set. You should then be able to see the menus again, so that you can reset the TV scart picture settings through the menus to either RGB or PAL.
