Quantcast
Urgent ! Please help
paulcollins14
I am producing a dvd project that was going quite well, because of the size I have had to use 2 dvd-R's the first transfered perfectly, the chapters just as they should be, the 2nd will not copy to the blank dvd.
The error message is : could not complete last command because : Found PG with no video (DVDRR,-1)
What does that mean ?
I have used Windows MM2 to edit and transfered it to Sonic My DVD 5.2 for the authoring and encoding.
I need to take fix this problem tonight for a work meeting tomorrow and am totally stuck at the moment.
Thanks if you can help.
Paul
vonhosen
Never used Sonic's MyDVD but with Sonic's DVDit that error "Found PG with no video" could come up for a number of reasons.
Most common were
1) Chapter points set too close together (have you inadvertently placed a chapter point on top or very near another ?)
2) If you are using a VBR (variable Bitrate) encoded file the software is estimating the file length & you have placed a chapter point beyond it's estimated length (so remove chapter point if close to end of file)
3) Illegal MPEG file (usually wher the file has been cut & video is missing from stream)
