URGENT! Need some help with PS3 setup!
Discussion in 'Playstation Forums' started by SmilezKillz, Feb 8, 2009.
  1. SmilezKillz
    SmilezKillz
    Feb 8, 2009
    5
    Hey guys,
    Basically I've bought a PS3 however to be use on my iiyama ProLite E2003WSV-B1 monitor (official XL LAN monitor). I previously used it for my Xbox 360 (which is now broken) and I used a VGA Cable which I bought from amazon here's the link for that product:
    http://www.amazon.co.uk/Sumnique-Com...4117687&sr=8-1
    This worked perfectly, however finding a similiar cable which is compatible for the PS3 doesn't seem as easy. I have come across 1, however some of the reviews it's been getting is bad so not sure if it's right for me. Here's a link for that VGA Cable: http://www.amazon.co.uk/Playstation-...4117863&sr=1-3
    There is however one VGA Cable that has nothing but great reviews and that the HDFury VGA Cable: http://www.amazon.co.uk/HDFury-Gamer...4117933&sr=1-3
    The only problem with this cable is that it won't allow me to have audio/sound. Unlike the Xbox360 VGA Cable I bought before.
    Basically, I'm wondering if you experts could give me a bit of advise as to what I should do.
    Any help at all will be much appreciated [​IMG]
    Thanks,
    Shaun
  2. _Sion
    _Sion
    Sep 26, 2006
    701
    43
    Newcastle upon Tyne
    +118
    If you're video lead won't carry audio is there another audio input on the monitor? A lot of DVI TVs/monitors have an audio input 3.5mm jack, that with an adaptor you can plug the phono leads into.
  3. SmilezKillz
    SmilezKillz
    Feb 8, 2009
    5
  4. SmilezKillz
    SmilezKillz
    Feb 8, 2009
    5
    Bump still in need of some help :thumbsup:
