URGENT mission fs2 av centre speaker problem
PaulaB
I was watching LOTR when the centre speaker dropped out. I looked at the wiring and it looks fine. I then swapped the centre speaker with the front left speaker and ran the test on my amp. Everything worked exept the front left so its definatly a problem with the speaker, do I need a new speaker or is there something I can do.
PaulaB
Originally posted by Shirker
How old are the speakers? I think the set I purchased came with 1yr warranty
end march 2002. I have emailed the company (I can't ring them Iam on 12 hours this week.
gdickin2
If you haven't already done so, take off the grill and pop out the NXT panel to reseat it, and check if the connections are making OK. The push in connections from the panel aren't the best in the world.
If you are out of warranty, you can contact Graham Bloxham at Mission and he will sell you a new panel or any other parts for that matter. I have just bought some new grills off them, they come in a whole range of colours other than the usual Silver/Grey/White.
