Urgent laptop buying advice needed
Discussion in 'Desktop & Laptop Computers Forum' started by hab92, Aug 6, 2013.
  1. hab92
    hab92
    Sep 23, 2009
    79
    +4
    I'm looking to buy a laptop, but honestly everywhere I look, I end up choosing something else, so hopefully you guys can help me out. If you don't think it's possible to find one within my range, feel free to tell me.
    Budget: £700 (preferably less, might be willing to stretch to 800)
    Specs:
    Processor - Intel i7 Quad-core
    Hard drive - 1TB
    RAM/Memory - 8GB+ (with 2 GB dedicated Nvidia Graphics)
    Screen - 15.6+ (Full HD preferable)
    Optical drive - BluRay (much preferable, but not necessary) along with a HDMI port
    It'll be used for browsing, documents, streaming videos and downloads, and maybe occasional gaming. I won't really be taking it anywhere so weight/size isn't a problem, and also battery life shouldn't be an issue, as I'll probably keep it charged all the time. A newer model (ie 2013) would also be preferred. Also, would it be possible to get one with a SSD?
    So I'll leave it to you guys to advise away. :smashin:
  2. thedude
    thedude
    Oct 18, 2004
    10,162
    Swindon
    +2,067
    I got a Dell uktrabook from eBay. Cancelled order £500 i7 processor 8gb ram amd graphics and an ssd it's quick and goodm screen isn't that great though. But it was £500 so I'll settle for that
  3. MandyAW92
    MandyAW92
    Nov 29, 2012
    131
    +9
  4. hab92
    hab92
    Sep 23, 2009
    79
    +4
    What's that website like in terms of reliability, delivery, etc? I've never heard of it, but if it is good enough, I'll give it a go.
    The MSI has been considered, especially as I'm not too fussed about looks. I just want the performance, which this has been lauded for. The only drawbacks would probably be the lack of a Blu-Ray drive and non-Full HD screen.
    To the poster above, what kind of reviews does the Dell have?
  5. MandyAW92
    MandyAW92
    Nov 29, 2012
    131
    +9
    I bought from the site and have had no issues, everything arrived on time and in the condition i wanted it in
  6. hab92
    hab92
    Sep 23, 2009
    79
    +4
    How quick is the delivery, and is it free?
    I've found the same model with the Full-HD and BluRay drive, albeit without the SSD for £50 more. Do you think that would be worth it?
  7. MandyAW92
    MandyAW92
    Nov 29, 2012
    131
    +9
    Yeah its free delivery within 5 days, if you want it sooner you have to pay. If the BluRay and Full HD are more important to you then yes it is worth it but if, you are only getting them for the sake of it then no
