URGENT Is my Sky+ About to Die...
Discussion in 'Sky Digital TV Forum' started by Anastie, Oct 27, 2004.
  1. Anastie
    Anastie
    Jul 15, 2003
    1,960
    63
    UK
    +208
    Had my version one box (the £99 deal :thumbsup: ) for over a year now with no problems. Until now.
    Over the last few days some recordings fail, the planner looks fine "recorded" then I go to view and sky+ freezes until I go into normal sky viewing. Then go back into planner and the "recorded message now reads "failed" This has happened 4 times tonight. I have updated software and done system reset.
    Anythoughts before I pay out the standard £65 fee for repair? :eek:
  2. Anastie
    Anastie
    Jul 15, 2003
    1,960
    63
    UK
    +208
    Please someone must have an answer! :)
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,748
    2
    In a secret location with Jennifer Lawrence
    +9,538
    If you have tried all the major things you can do yourself, which you mentioned, such as full complete system reset, etc then it sounds like it's on the way out.
  4. mps
    mps
    Oct 16, 2001
    1,588
    London
    +57
    Have u tried doing the housekeeping option:
    You can do this by pressing services 401 Select and choose the housekeeping option.
    WARNING - THIS WILL WIPE THE CONTENTS OF THE HARD DISK
    This should fix the problem :thumbsup:
  5. Anastie
    Anastie
    Jul 15, 2003
    1,960
    63
    UK
    +208
    Thank all. I will do the housekeeping and if that fails to sort it ring Sky :(
  6. Cynthia 7
    Cynthia 7
    I had the same problem, Anastie, last year. Sky talked me through a procedure, which I presume is the housekeeping option, as they warned it would wipe the contents from the hard disk. After that everything was perfect so I hope that works for you too.
