urgent help with my denon 3803 please!
Discussion in 'AV Receivers & Amplifiers' started by lotusman1, May 24, 2003.
Tags:
  1. lotusman1
    lotusman1
    Feb 13, 2002
    277
    cheltenham
    just got a denon 3803 amp ant mordaunt short thx package delivered today,have set it all up and was really dissappointed with the bass delivery,have fiddled with all sorts of settings to no avail,so hooked up the m/s to my old sony strdb930 and lo and behold bass aplenty!whats going on with the 3803?what have i missed?please don't tell me i've bought a lemon:(
  2. nathan_silly
    nathan_silly
    They need running in.. amp & speakers.
    Play some music for at least 8 hours at background level volume whilst you go to work (stick a CD on replay)
  3. lotusman1
    lotusman1
    Feb 13, 2002
    277
    cheltenham
    i don't think it's that really i mean when played through the 3803 there really is almost no bass extension whatsoever.
  4. nathan_silly
    nathan_silly
    What crossover have you set on each speaker?
    And are all speaker drivers working?
    Perhaps you're used to the Sony droany boomy bass?- wheras the Denon is cleaner.
  5. damtom1
    damtom1
    Definately worth going through the On Screen Display and looking at the crossover level and that your speakers a set correctly (Large/Small).
    I've only had mine a few weeks,but one of the bigget improvement i noticed was with the bass delivery.The sub seemed to be more precise and "located" to the rest of the sound.This was also very noticable because all my other speakers seemed to have a clearer sound.
    Its definately noticably better ,after a running in period,...everything blended in nicely.
  6. lotusman1
    lotusman1
    Feb 13, 2002
    277
    cheltenham
    so do i set the fronts to large or small?what have you got your crossover set at?The amp seems a lot more complex to set up than the sony and from what i've been led to understand the speakers can take a lot of tweaking as well(the left front will have to go back anyway as when i unpacked it one of the binding posts had sheared off)!
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    Use the OSD and enter the Setup Menu. Set all the speakers to Small, route all bass to the subwoofer and leave the crossover of the amp set to 80hz. Set the crossover on the subwoofer to MAX or if it has a Direct Crossover Bypass of some sort, switch that ON.
    You'll also need to key in the speaker distances so the amp can set the delay times. Once in the menu, you'll find it a lot easier.
    Ideally you need to balance all the channels to 75db including the sub with a Sound Level Meter, if you haven't got one then you'll have to do it by ear.
  8. damtom1
    damtom1
    I have mine set up exactly as Jase described.Maybe try and listen to something whilst scrolling through the crossover settings(24/40/60/100/120hz).This will definately show a movement of bass between the sub and the fronts,...if there is any!!
    Is your cable to the sub fine?or maybe in the wrong connection on the back of the Denon....(i did this)
  9. lotusman1
    lotusman1
    Feb 13, 2002
    277
    cheltenham
    thanks for all the replys,i've sussed it out i think,i did'nt have the subs connected via the sub out on the amp at all as the retailer said i could run them without,so i just connected them up with some phono cables and hey presto loads of bass!They sound awesome!But i've got to pack it all up now as i'm moving house,don't know when i'll get to set it all up next.
