Urgent help pls with TH-AE200 Powerstrip settings
Discussion in 'Desktop & Laptop Computers Forum' started by jbalat, Jan 17, 2003.
  1. jbalat
    jbalat
    Does anyone have it set up ?
    Should I be using Wide480 mode as per the manual ? for watching PAL DVD's
    The picture looks shocking so far in 4:3 resolutions
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    This most likly uses the same settings as the ae100, if so then they are
    PowerStrip timing parameters:
    856x480=856,40,72,80,480,4,5,11,31500,342
    1280x720=1280,56,120,240,720,4,6,20,76500,342
    Hope that helps.
  3. jbalat
    jbalat
    Ta,
    I will give it a try soon. I think you are right about the AE100 settings
    The only problem I have now is how to switch from projector to monitor. I have to unplug and plug the rgb's. I have been told I will lose too much quality if I use a switchbox ?
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Better off with a dual output radeon and then use hotkeys in the control panel to enable/disable each monitor, I use F1 for the pj on its own and F2 for dual output when I need to use the monitor.
  5. jbalat
    jbalat
    I have a Motrox Marvel which is great for DVD and has a TV tuner, unfortunately only supports 1 monitor and a TV. I was thinking more of a cheap twinview Geforce however I am not sure what the DVD quality is like. I know TV out sucks but you dont really need that...
    Do you have any experience with Zoom Player. I am using WinDVD and just want to scale off the black borders on those anamorphic 16:9 dvd's. I played around with zoom player and the picture went black and white. I trie to get it back but now it just crashes with a violation error ?
  6. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Sorry no, I havent played with this at all, I'm currently using Theatretek for DVD duties.
  7. jbalat
    jbalat
    Do you know of any demos I can download ?
  8. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
