lrac79
I am in the process of creating my hc room. I have boxed it out with stud work and boarded one side (I can still install wires at the min) problem is I thought I had another week to sort the cabling but it turns out the plasterer is arriving tomorrow! Seems I got my cables crossed!
I have run the speaker wire round, and the twin and earth for all the sockets required. I have just put in 1no hdmi cable. I was planning on plugging the hdmi cable into my amp and tv and running everything thru the amp I.e. Sky box, blu ray and x box etc. Question is can you think of anything else I need in the walls before they get plastered?
Any help would really be appreciated
Thanks!
Thanks!
