Urgent Help Needed
Discussion in 'Cables & Switches' started by SCOTT_SCOTLAND, Jun 28, 2004.
  1. SCOTT_SCOTLAND
    SCOTT_SCOTLAND
    Whats the best way to connect a plvz1 to a video recorder?
    This will be to watch the occasional football match, nothing else.
    Phono cable or S-Video?
    And it looks like there will be a tv cable running from downstairs from the sky box, upstairs into the video recorder and then into the PJ. What sort of picture should i expect?
    Cheers :cool:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    You can only connect something that outputs s-video to an s-video socket and unless your VCR is an SVHS model, it won't
  3. Ianfromnotts
    Ianfromnotts
    May 16, 2003
    2,724
    Nottingham
    +171
    I suspect you will get a better picture using the rgb scart out put and feeding into the rgb vga input keene do a lead £39.99 for 10m product code sbb955
