Urgent help needed regarding hdmi
Discussion in 'Plasma TVs' started by BB-frank, Sep 21, 2005.
  1. BB-frank
    BB-frank
    I went to richer sounds yesterday and bought their hd ready pioneer plasma and was told that i could connect 2 hd devices to the set but their is only one hdmi slot.
    I am going to take it back tomorrow for a refund unless their is a way to correct the problem...on getting a refund could anyone point me in the direction of a set that i can connect an hd dvd player and the sky hd when it arrives.
    Sorry in advance if i have posted in the wrong place but i need to get this sorted asap :)
  2. paulefox
    paulefox
    Feb 8, 2003
    1,293
    Bury St Edmunds
    +43
    You can get an adaptor to plug two HDMI leads in but it is quite expensive The new Pioneer 436 has two on it
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    What Pioneer model is it?
  4. av2diefor
    av2diefor
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    the two HD connections are component and HDMI
  6. BB-frank
    BB-frank
    The model i bought is the 435xde but i also noticed that the 436 has a bigger contrast ratio so will i do better to get a refund and go elsewhere or is the set i have a good one.
    What initially got me worried was that the guy at comet said that i should have got the new 436 but because of all the poor set ups at comet i went for the pioneer.
    ps. thanx for the input so far peeps.
  7. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    sky will connect via component
    dvd via hdmi
    no need for 2 hdmi slots
  8. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    Sky will indeed connect via component in the short term but not in the long term. You need 2 HDMI sockets.
  9. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    It can't be too long before (and i know there are some now but pretty expensive) av amps will offer more in the way of HDMI connections.
