URGENT HELP NEEDED!!! Panny DMRE85...
Discussion in 'Blu-ray & DVD Players & Recorders' started by bodgery, Mar 1, 2005.
  1. bodgery
    bodgery
    Feb 14, 2005
    20
    Hi all
    I've ordered a Panny DMRE85 (it's due to arrive today), but after reading posts on this site (which sadly I didn't spot until after ordering) I'm worried! Here's why:
    1) Seems like it's VERY SLOW and potentially hugely annoying as a result;
    2) Might be noisy.
    Can someone put my mind at rest, or should I just go with my alternative solution of Toshiba SD340 player + some sort of PVR like a Humax.
    I've read it's slow on startup and slow to recognise/start playing a DVD when you put one it, plus reinitialises after leaving the navigator menu???
    The urgency is because I might be able to stop the delivery this morning and change to something else.
    I hope someone out there can help!!!!
    Bodgery
  2. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    I have a DMR-E85 and have not noticed a noise problem. It is slow to power up and off (about 30 seconds) and takes a while to load a disc.
    I feel however these are minor annoyances when compared overall with the product.
    Ty
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have the DMRE-95, and I've yet to hear any noise. The machine will be slow to startup, because it has to initialise the hard drive.
  4. bodgery
    bodgery
    Feb 14, 2005
    20
    Does it initialise during operation, or just on power up?
    Do you leave it on all the time? I assume it has a standby mode, rather than total power off? Assuming it does, does it still need to initialise?
    I feel a little better...!!!
  5. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    I leave mine on all the time as my SKY+ passes through it to my plasma. The HDD will go to sleep but only takes a few seconds to wake up.
  6. HMHB
    HMHB
    Nov 11, 2001
    27,517
    Nottinghamshire
    +6,438
    I've not noticed any noise from mine either
  7. StuartW
    StuartW
    Have the 55. No noticable noise. Power on/off times are 30ish seconds, not too much of an issue.
  8. adrianl
    adrianl
    Start-up is about 30-45 secs from 'cold'. You don't have to set it to standby though as drive sleeps by itself. Mine gets turned off only because it's smart-linked to TV so it powers down when TV set to standby.
    DVDs take a few seconds longer to be recognised than by normal player but not an issue.
    Noise non-existent, other than fans whirr for a few seconds when it begins to finalise a recorded dvd. I find this noise quite reassuring in telling me things are happening OK!
    If you leave 'navi' menu by pressing 'return' then it doesn't go to standby. I didn't realise this when I first got it and would press the 'navi' button again which would set it to standby.
    Overall a brilliant machine - never realised how valuable the HDD/DVD capability would be both for tidying up recordings and for archiving. Richer Sounds were doing the multi-region at £299 last weekend! I was happy to pay almost double that (though I got £250 off as part of a John Lewis deal).
  9. bodgery
    bodgery
    Feb 14, 2005
    20
    Well thanks for all the feedback! Machine arrived, just set it up and........what was I worrying about!!! First impressions are what a fantastic bit of kit!!
    Bye for now
