URGENT HELP NEEDED ! LG RZ42PX11 and Vivanco Bracket.......
Discussion in 'Home Cinema Buying & Building' started by Daipac, Apr 29, 2005.
  1. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    Trying to put this on now. The stand is on the plasma at the moment. When you take the screws out to take the stand off, do you then use the hole to mount the bracket ?
    Do you need to use any of the spacers that come with the mount ?
    A step by step guide or any help would be appreciated as it MUST go on the wall tonight !!!!!
    :lease: :lease: :lease: :lease: :lease:
  2. Daddy k
    Daddy k
    Jul 19, 2004
    9,044
    coventry
    +1,345
    i dont think so mate hopefully someone with a mount can get in touch quick!
    the wait must be killing u
  3. zorg
    zorg
    the top screws that hold in the stand do not go back in as they attach themselves to the stand brackets, once the bracket is removed there is nothing to screw into, 6 screws have held my bars on no problem, i used threadlock on them as well
    zorg
  4. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    Thanks guys ! The LG is now on the wall and I am loving it !
  5. welsh113
    welsh113
    Oct 9, 2004
    602
    +10
    pics please :)
  6. Daipac
    Daipac
    Apr 12, 2005
    658
    +12
    I have to hide the wires first but as soon as I do then I will post up some pics.
