Trying to set up my new Panny AE100 to watch the Chelsea v. Arsenal game tonight. I have run an S. Video cable from PJ to telewest digibox. I am getting no sound and pic is black and white. What's the best way to connect?
Hi, If the video is black and white, then you should check in the menus of your digibox that you've set it to output Svideo. What are you doing about sound ? I assume that you're sending the L&R audio from the Digibox to an amplifier/whatever. If you're using a scart breaking out to Sviideo, L&R audio, then you should check that the digibox is capable of Svideo output as above. Hope you get it sorted... Sean G.
