Urgent answer needed....
safcalibur
The Coda 80's are discontinued arent they?
I dont think theres much between the two, coda 80 is ever so slightly easier to drive and imo looks better. Dont like the design of the iq2c.
I'd g with coda 80 if you can find it
Saf
EDIT: What do you have as fronts?
bluechilli
Thanks Saf
Ebay Im looking at the moment.
I am using the Onkyo HTX-22HD system and so I have the standard Onkyo fronts. Just trying to build my little system up really.
safcalibur
Hi mate,
No probs. Just a quickie, i dont know how well either kef will match with the onkyo speakers.
Ideally you would want the same speaker or make of speaker accross your front three. This would ensure a tonal match accross the front soundstage. If you have different make for centre and different for left/right then as the sound passess from one speaker to the other it will not be a smooth transition.
Just something to consider mate if you didnt know already.
Saf
bluechilli
Oh!!
Im new to all this home cinema stuff and didnt consider this. :facepalm:
I might get one anyway as I cant find the Onkyo centre and I need something below the TV.
Or is that just stoopid?
safcalibur
Oh!!
Nah i wouldnt say the 'S' word!! Unwise maybe lol!! I dont know how they'd sound together mate tbh, they may sound ok but after buying the centre i would def look at replacing you fronts. The KEF woud outclass the onkyo speakers. Onkyo are more renowned for their amps, so i would be looking to change the left/right asap, funds permitted of course! There's also the very real possibility that it sounds fine to you and at the end of the day, thats all that matters :smashin:
Saf
safcalibur
bluechilli
I know about these Saf, they have been discontinued I think.
Another stoopid (unwise) thing to say but I dont really want / need (so the wife says) the rears. Our little house is fine with just front stuff going on.
safcalibur
Lol! No worries mate, best of luck :smashin:
Saf
