HadHa
I have a double patio upvc door which needs some adjustment. One of them are perfectly level with the frame whereas the other appears to be tilting, see alignment pic.
I wanted to attempt adjusting it on the door hinges. Prying off the top and bottom covers reveals some screws but having done some rotations I still can't tell what is the correct screw or way to rotate.. I'm a bit worried about continuing screwing at these without knowing what I am doing.
Do anyone know what I'm looking at on the top panel off image? I can't seem to find any product online which has the same screws as mine.
My expectation would be that the leftmost (big) screw controls the height of the door and that the other two, smaller screws somehow control the tilt.
I also don't really know how to best do this: Do I screw all 3 hinges on a door together half a turn at a time or just the one hinge a half turn at a time?
Any help appreciated - this is all new to me.
