Upside Down Lcd Tv - Damage?????
Discussion in 'LCD & LED LCD TVs Forum' started by allazey_uk, May 4, 2007.
Tags:
  1. allazey_uk
    allazey_uk
    Apr 19, 2007
    754
    +79
    Sorry guys but this is a bit a 'fussy' question.....
    I bought a Samsung 32" R88 for the flat i'm moving into soon so last night i decided put the TV back in its box and leave it until i move in.
    It was quite tricky taking the stand off and getting the TV back into the polystyrere. I managed to get it back in the box eventually without dropping it.... BUT........... when i was holding the TV trying to turn it around (almost upside down but not totally) I heard a noise as if something moved inside!!
    Its hard to describe the noise but i can only liken it to this: Imagine if you had a glass cup with something metal inside it. The metal object inside was almost a perfect fit, but there was still a millimeter space around it. If you moved the glass from say left to right you would hear a slight clunk where the metal object inside has moved and knocked against the side of the glass.
    WELL THIS IS WHAT I HEARD!!!!!
    I know this is a long shot but has anybody else experienced this???
    And also, how safe would you lot say it is to turn a TV almost upside down??? Could it do damage???
  2. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    You can turn it whichever way you want, don't worry about that, mine was delivered "upside down"
    As for the noise you heard I don't know:confused:
  3. 00boz00
    00boz00
    Jul 26, 2007
    3
    I just brought a sony 32v4000 and was taking it up some stairs at angle and heard a cluncking noise come from inside the tv. :eek:Then I turned it back the opposite way and it made the same noise like someting isnt quite tight. Should I be concerned or do all sony lcds make this noise when turn on a angle.
  4. williamwallace
    williamwallace
    Did you hear any additional responses on the below? similar thing happened to me. thanks
  5. EarthRod
    EarthRod
    Jul 15, 2008
    17,768
    England
    +7,870
    Hi Guys
    I'm only guessing, but what you are hearing is possibly a cable or ribbon cable slightly moving position inside the TV as you change the angle.
    Alan
  6. williamwallace
    williamwallace
    Thanks for the response Alan. Yea.. i'm guessing it's nothing big. tv seems to be working fine..
