Upside down image
Discussion in 'Projectors, Screens & Video Processors' started by Brucelockie, Apr 5, 2005.
  1. Brucelockie
    Brucelockie
    I purchased a ask impression 960 off ebay for under a hundred quid. the only problem is that the image is projected upside down. I don't have a remote and was wondering if anyone knew how to change this.
    Bruce
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
    It has been set for ceiling mounting probably. You need to select the menu button, then go into settings or similar. You are looking to 'untick' the ceiling mount option which should revert it to the right way up.
  3. Brucelockie
    Brucelockie
    don't have the remote so can't access a menu screen or anything. is there a way of fliping the image with an additional lens?
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
  5. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    If the buttons on the PJ (assuming that there are some!) don't give access to the menu that sets ceiling mount / floor mount how about a programmable remote with the PJ's remote settings (downloadable from various sites, try my sig if you can't find them) - or even the PJ's original replacement remote?
  6. yoskiwoski
    yoskiwoski
    May 25, 2004
    336
    +10
    or put the projector upside down! :rotfl:
