Upscaling via Laptop
H
hardhousehead
I currenctly have the follwing spec laptop:
Intel Core Duo 1.66ghz cpu
1 gig ram
geforce 7600 256mb gfx card
100 gig HD
Can I use this to get better upscaling results then a Samsung HD860 dvd player?
Rambles
You certainly can upscale with it - I would reccomend ffdshow and theatertek software, whether it would be better that your DVD player is a subjective opinion. But, with ffdshow you can apply infinite tweaks so you should be able to achieve a very good result.
H
hardhousehead
Ok
What cables do I need to connec t it all together. I have only one dvi port on my laptop.
ChrisOH
You need to have a software DVD player eg Theatre Tek installed on your lap top. This will replace your current DVD player when you connect the lap top to a monitor using an appropriate cable (DVI?).
Chris
Rambles
If you have a DVI connection on your display then go for DVI to DVI, and you would also need to route the sound to your dispaly - or amp - via the audio out on your laptop.
H
hardhousehead
ok I think Il need to get a DVI to HDMI lead as my plasma dont have a DVI connection.
Similar threads
