Upscaling through component leads
Discussion in 'Blu-ray & DVD Players & Recorders' started by dynamodav, Jan 23, 2008.
  1. dynamodav
    dynamodav
    Jan 9, 2006
    +3
    Would an upscaling dvd player send the upscaled image through the component connection or will it only be the hdmi connection?
  2. martin purnell
    martin purnell
    Jun 28, 2005
    542
    28
    +50
    My understanding is upscaling can't be done through component because of copyright reasons. However, there were a couple of models from Oppo and Samsung that flouted this. Considering you can use component for upscaled and HD pictures courtesy of a Sky HD box, we live in a really daft (or should that read greedy?)world !
  3. Peopleselbowpad
    Peopleselbowpad
    Jan 13, 2007
    870
    Middlesbrough
    +53
    Helios H2000 and H4000 both upscale through Component. High fault ratio though so get them from Superfi in the UK as they are superb when returning an item if you fancy one.
  4. imjay
    imjay
    Jan 30, 2008
    175
    +24
    If the issue is copy encryption then can't he use a simple decrypter, load that file to HDD, compress as necessary and burn back out as a disc that will allow up conversion benefit via component out of the DVD player??
  5. jerrymac
    jerrymac
    Dec 14, 2006
    246
    Cork/Ireland
    +28
    Try the Kingwell 6900i...Allows upscaling to 1080p over component...£79 ...google it..
