Upscaling SD to HD?
Discussion in 'Televisions' started by rushers, Aug 1, 2005.
  1. rushers
    rushers
    Mar 30, 2005
    Newbie needs help :lease: . I live in South Africa, we only have SD satellite channels at present and because of numbers it does not look as if the main satellite broadcaster will be able to expand bandwidth at present (1 mill users vs Sky with 8 mill users). This looks like it may only happen b4 the 2010 world cup. Many microdisplay TVs are available which are great for the DVD users, but I watch mainly sport and satellite channels. Is it possible to upscale the incoming SD signal from satellite to 720p or 1080i so as to :lease: get the full value from one of these very expensive displays? If so how? I know that some hd DVD players have onboard scalers and one can buy seperate upscaling boxes, but I thought that this was only for upscaling dvds.
    Tony
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    A standalone scaler will accept many sources via component, s-video, DVI/HDMI and do all sorts of tricks before sending the results to the display.
    The Video processor forum here is a good place to start.
  3. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    You could always use a pc to scale.
  4. dsb
    dsb
    keep in mind that scaling a signal to a hd resolution will not make it look like a hd broadcast - it will look like a dvd does if you play it on your pc set to a high resolution.
  5. rushers
    rushers
    Mar 30, 2005
    Thanks everyone, your input already helpful. :thumbsup:
    Gareth, I have not seen any HD broadcasts - How much better does it get than current DVD standards because compared to our poor SD input, DVDs on these displays look awesome to me.
    Does the resolution/PQ improve as compared to SD or does the scaler just "fill" the display better?
    I see some of the dvd players have internal scalers, can one input the SD satellite feed via the dvd player and onto the display with upscaling via the dvd?
