  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Upscaling DVD Players List
Discussion in 'Blu-ray & DVD Players & Recorders' started by PoisonIvy, Sep 18, 2005.
  1. PoisonIvy
    PoisonIvy
    I'm looking for a decent upscaling DVD player with HDMI to HDMI outputs.
    So far I've found the following at a reasonable price:
    Samsung DVD HD850 (less than £100)
    Toshiba SD350E (less than £100)
    Philips DVP9000S (£200-£300)
    Any know of any more?
  2. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    i'd like one that upscales thru component and is multiregion. if anyone knows of one that is available in the UK, that'd be good.
  3. nealgs
    nealgs
    Add the Momitsu V880 and V880N to that list (upscale over component and DVI)
    Gary
  4. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    If you compile a list of these 'upscaling' players, separate out analogue and digital as upscaling may be different.
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    The Samsung HD745 upscales via component once the hack is applied, the only problem is the picture stinks via component. One bright spark on this forum has identified and removed the offending capacitor (I think) which seemingly Samsung put in the signal path in an attempt to make it look artificially inferior to the DVI output...PJ :)
  6. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    Now find a UK retailer and we're laughing :lease:
  7. Goone
    Goone
    Oct 21, 2003
    118
    uk,london
    Oppo DIVX DVI DVD Player- OPDV971H
    supposed to be one of the best in its price range
  8. kevinsmith98
    kevinsmith98
    Jan 31, 2005
    84
    I am hopefully about to take the plunge with a 40" Sony LCD (V-Series) :thumbsup: I just need to convince the SOH on the aesthetics/size/cost!
    having read a number of threads on this forum, i remain unconvinced that an upscaling DVD player provides a significantly better picture than prog scan over component. all i seem to see ae concerns with Blocking, poor quality DVD's giving poor quality output etc etc.
    has anyone got an upscaling DVD hooked up via HDMI to a HD screen and if so are they really happy with the result? :lease:
    In other words, is it worth going upscaling or would the prudent choice be to wait for HD DVD &/OR BluRay to get themselves established in the market place and get a true HD output to the HD screen?
    Kevin
  9. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I'm happy with the Oppo, but wasn't happy with the Samsung HD745. In other words, it depends on the player/screen combination - results can be poor / OK / stunning - but until you try it you're not going to know, unless someone has the identical setup as you and comments on this forum.
    I wanted the versatility of having two players hence why I bought the Oppo. I also figured I'd get a good few years out of it before I take the HD plunge. However, I'm more than happy with the quality of the Pioneer 575 via component.
    In the end it comes down to whether you can resist not having something plugged into that HDMI socket...PJ :D
  10. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    The SD350 is scalable, I never knew that. Nor can i find any reference to this anywhere. Please do tell more....
  11. mjcairney
    mjcairney
    Oct 26, 2003
    6,897
    2
    4
    137
    Airdrie, Scotland
    +856
    Add on:
    Denon DVD-1910, DVD-2910 and DVD-3910.
    Also, the Panansonic S97, although very difficult to buy now.
    Cheers,
    Martin.
  12. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    What about upscaling through DVi to VGA Adapter?
  13. kourosh
    kourosh
    Feb 6, 2005
    13,843
    Portsmouth
    +907
    if you wait til next month sony has 2 hdmi players out 1 of them with a 250gb hard drive :thumbsup: i tried my panys97 with the s version of the lcd your looking at which dont have the wega engine and the picture looked very good :smashin:
  14. bluecupra
    bluecupra
    Do you have an link to more info? I haven't seen anything on the Sony site conserning these two models.
    Jeffrey
  15. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
  16. Fluffy-Bunny
    Fluffy-Bunny
    How much would you pay for a Panasonic S97?
    I have seen a few go on Ebay for around the £200 mark, seems quite steep.
  17. mjcairney
    mjcairney
    Oct 26, 2003
    6,897
    2
    4
    137
    Airdrie, Scotland
    +856
    Does seem a bit steep - a few have sold on these forums lately for a good deal less than that - I am sure if you do a search you'll see some examples of what I'm talking about.
    Cheers,
    Martin.
  18. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Yes, that does look the dog's 'NADs doesn't it?
    Bet it's not cheap...PJ :)
  19. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    Shows that beauty is in the eye of the beholder - it's horrible!
    Mind you I don't care about how it looks so I will add it to my list of HD950 replacement contenders along with the Denon 1920. Shame the Oppo doesn't do SACD.
    Anyone know when the NAD is being released ?
    Ray
