Upscaling DVD Players - are they worth it ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Juddy, Mar 9, 2006.
  1. Juddy
    Juddy
    I've bought a Pionneer 436xde plasma and was wondering whether it's worth buying a upscaling DVD player such as a Denon DVD-1920, or just use my 5 year old Sony DVD via a scart lead and wait til HD DVD comes out ? Does anyone run a Denon DVD-1920 through a HD plasma TV ? Your thoughts ?
  2. steve998
    steve998
    I presume your TV has digital connections and component connections?
    I noticed a big difference going from RGB scart to component connections and progressive scan. My experience with DVI/HDMI is that the quality looks more 'sharp' and 'edgey' and component looks more 'soft' and 'natural'
    I borrowed one of the 'upscaling' Denon dvd players and I prefered the Harman Kardon DVD 22 that I have got (component connection)
    I am sure many would disagree BUT my experience was that a £200 player using component looks 'better' than a compromised 'upscaling' player.
    Cant comment on the more expensive players, i am sure they could look better on HDMI.
  3. AgentCool
    AgentCool
    Aug 5, 2004
    2,653
    Yorkshire
    +184
    It's definitely a matter of personal taste. From my experiences, 576p via component looks a bit softer and less detailed than 720p via HDMI. However, this can work both to your advantage and disadvantage as a more detailed image results in more picture noise being visible on poorly mastered discs. The difference is pretty small though.
  4. blackeyepurple
    blackeyepurple
    I have the 436FDE and a Samsung DVD HD950 connected via HDMI and the picture is very good (no macro blocking or jaggies). I wanted to upgrade and got the Denon 1920 on line......I was very dissapointed with the image even after playing with the settings. The Denon gave jaggies even though its has DCDi. I sent it back and got a refund. I'm not sure if the Pioneer has a problem with the Denon as may users with other screens seem to like this player.....but with the 436 I think you will be dissapointed. I tried the player over component and HDMI and the results were pretty much the same.
  5. Juddy
    Juddy
    Thanks for the advice. Decided to go the HD950 route for now - bought one yesterday and the pictures are great! Will start saving for the HD DVD / Blue Ray......thanks again. Juddy
  6. fidelityutensil
    fidelityutensil
    Mar 9, 2006
    28
    Do you mind me asking where you got the 950 from, and how much it cost?
  7. Juddy
    Juddy
    Apologies, it was the HD850 that I bought in the end. Read lots of on line reviews (lots of info in this forum) that indicated that there wasn't much difference picture wise. Think the HD950 is higher spec but I didn't require all it offered, as I solely use it to play DVD's. Also, I didn't go bargain hunting with this item (unlike my TV), so paid the full £99 at Comet so I could try it over the weekend. Appreciate you can get it for £15 less mail order. Cheapest on pricerunner is about £110-115 for the HD950 I think. What TV do you have ? I question whether upscalers are worth the money if you have a decent TV upscaler in the TV itself. My previous Sony DVD player gave a great picture from a RGB scart into my Pioneer.
  8. V5-APS
    V5-APS
    May 7, 2001
    681
    London
    +15
    The HD950 is available from Richer Sounds....not online, but if your local store has one, you are in luck :)
  9. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    you're using scart on a screen like that :eek:
    thats criminal!
    even a cheapish player with progressive scan, connected via component will give a HUGE improvement :smashin:
  10. AVdavid
    AVdavid
    Play.com have the HD950 for £118 free postage
    Dave
  11. Juddy
    Juddy
    As mentioned, I bought the Sammy HD850. Playing it through HDMI and the picture is great! Bumped up the sharpness a little on the TV to levels higher than I have for freeview as the upscaling works a treat and can take it. Great detail. It will certainly keep me going until proper HD DVD / Blue Ray is released.
