medicmanonet
Established Member
Hi all,
I've got a few questions before deliving into making a HTPC so could you give me your opinions please
1. How good is a HTPC using something like FFShow at upscaling dvd's compaired to a dedicated HD-DVD player (HD-E1) / Blue-ray player or the PS3 (with latest patches).
2. If I installed a Blue-ray drive how good would the picture be compaired to a dedicated Blue-ray player or the PS3?
You see I'm in a dilema. I am probably going to buy a laptop for colledge work and will lilkly only get a cheap less powerfull one so it is unlikly to be much good at playing HD videos. I am tempted by the PS3 as this can play most HD format videos (from the net) such as AVC and maybe wmedia and surf the net.
My main use would be a DVD and HD/BR player, with maybe a bit of net surfing. The ability of being able to play other HD media files would be nice.
Ultimately, the wife can't beat just sticking a disk in and pressing play on a remote!
What is the lowest spect laptop needed to play HD movies at 1366x768?
I have tried some files ona works ;laptop with (I think) a 1.7mhz processor and onboard intel 945 graphics and it played on the laptop without stuttering.
thanks all
thanks all
