Upscaling AV amp - do they exist?
Discussion in 'AV Receivers & Amplifiers' started by Wonky, May 1, 2007.
  1. Wonky
    Wonky
    Apr 16, 2007
    22
    3
    Hi all,
    So, can I get an upscaling AV receiver for less than £1000?
    Current sources are std DVD player and Sky+.
    I'm currently buying my first AV system and am auditioning a set of M&K K5 speakers at the weekend. I'll also be discussing my amp choice with the chaps in the store so a bit of advice before hand would be useful!
    Tim.
  2. DolbyDan
    DolbyDan
    Sep 17, 2006
    2,103
    Canvey Island
    +265
    Yes check the onkyo 674 thread
  3. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    Or the Sony 5200 (not very good at up scaling though - your screen will probably do a better job)
  4. oddfeld
    oddfeld
    Jan 5, 2006
    302
    28
    Edinburgh
    +53
    The 674 doesn't upscale, it only upconverts. That is, it'll convert different inputs (composite/component/svideo) to output via HDMI, but it won't actually change the resolution of the signal.
  5. owenfarmer
    owenfarmer
    Sep 20, 2006
    6,764
    Wrexham
    +308
    i'm pretty certain the Onkyo 875 and 905 upscale images to 1080p through the Reon HQV scaler.
  6. nathan1977
    nathan1977
    The pioneer as4 axi upscales too
  7. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,931
    2
    The Fylde Coast
    +13,698
  8. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    for less than a grand? :eek: :eek: :eek: :eek: SHOW ME WHERE!!! :rotfl:
    sorry, couldnt resist..lol
    *gives himself an infraction for being cheeky*
    Dont be too concerned up scaling the amp, your TV will do that anyhow, especially if the amp cant output the same res as the TV, in which case you'll be scaling twice......its only worth worrying about if the TV is an older model, then the amps scaler may be an improvement....
  9. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
  10. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,931
    2
    The Fylde Coast
    +13,698
    I suppose there was a bit of a clue in the OP post, now that I've read it properly! :blush:
  11. Wonky
    Wonky
    Apr 16, 2007
    22
    3
    Thanks for the feedback chaps.
    I'm looking for this amp to be used with a projector (probably the Panasonic PT-AX100E) which won't do the scaling for me. I don't have a plasma/LCD as I still prefer my Panasonic 32" Aquity.
    The pioneer looks interesting and I've seen the VSX-AX2AS-S for £650 in a few places which also claims to upscale. Anyone seen any reviews?
    Tim.
    PS: Yes the Denon looks great but I really don't think I can stretch my budget that far!
  12. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    The projector you're looking at is 1366 x 768 rez...it should automatically scale the incoming images to that size otherwise all SD material will be very small.
    I must admit I'm not up on PJ's, so maybe someone with more knowledge can confirm.
  13. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    I use a Pioneer AXA4Si and it is simply stunning. I use it with an older sky box and Sony dvd autochanger with s-video output and it makes both of them look very good indeed. You are aware of the upconversion/upscale, to HDMI even more when you remove the amp and just plug in the source direct to the projector, the amp is certainly adding something and whatever it is it is great.
    When fed an upscaled image from a Phillips Dvd player it looks even better.
    The sound from this amp is brilliant, bass control is very good and the auto calabration very impressive, better in every respect to the Denon 3802 it replaced. I dont seem to be having the LFE problems that others suffer from when using HD/Blu-ray, maybe the newer machines have had this situation resolved. I am not able to comment in a highly technical way as I am sure some can on this forum but this Amp was certainly worth every penny I spent on it.
