M
Mastineo
Hi all
which do you think will give better results, MacBookPro or dedicated player?
Would I gain any improvement in image quality if I used a DVI to HDMI cable to connect the laptop to the screen (Sony KDL-40X2000)?
If a dedicated dvd player is the way to go whats recommended in the £100 - £250 range?
Thanks for any advice.
John
John
