UPS improves AE700 VB?
Discussion in 'Projectors, Screens & Video Processors' started by CooperUK, Jul 25, 2005.
  1. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    Just bought a UPS from currys for £30 (see my other thread in Hardware Bargains) and it seems to have made some improvement to the last vestiges of VB that I had.
    I'd have to really look for it now, despite being very aware of what was previously there (although not so bad after firmware 1.07 update).
    Any thoughts from anyone? I'd head that the UPS 'conditions' the power supply, but didn't think it would make so much difference.
    :smashin:
  2. tommouk
    tommouk
    Jul 5, 2004
    210
    28
    Fleet, Hants
    +26
    How much of an improvement from 1.07 firmware would you say has been made (10%, 20%....)?
    I have read over on AVS that some improvement can be gained by using 'smoothed power'.
    Tommo
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,230
    103
    +479
    That's interesting.
    I was planning on buying a UPS in any case as they are so cheap now it seems silly not to have one to protect the bulb from the odd power cut that we have during summer thunderstorms.
  4. Craig Armstrong
    Craig Armstrong
    Jul 28, 2004
    104
    Not addressing your VB comment, but I used a UPS to clean the power for my AE500 but it didn't help the bulb flicker problem. However, its peace of mind in case of a power cut :)
  5. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    Couldn't really say % exactly, but it is improved.
    Rough guess to try and be helpful 10-20% better - very little visible VB now (had next to none before - now have adjacent to none :D ).
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    Ive only seen VB once or twice on my AE700 and not in a ages now. I have always been using a UPS (£47 for 1200VA). I would be tempted to try without the UPS to see what difference it makes, however, knowing my luck, it would probably be the first and only time I get a power cut while turned on!
  7. tommouk
    tommouk
    Jul 5, 2004
    210
    28
    Fleet, Hants
    +26
    I bought this UPS, but I think it is faulty. :mad: After putting the battery in for the first time, I press the button on top and the light comes on green. The button light immediately goes out and a continuous tone is sounded. Did anyone else experience this?
    What I am expecting to happen is the green led to stay on whilst it charges. I can't draw any power from the unit because the green light goes out strait away.
    Any help would be appreciated
    Tommo
  8. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    Just a quick (and very stupid) thought - you have switched it on at the power supply wall socket haven't you?
    Otherwise, sounds like a faulty unit.
  9. tommouk
    tommouk
    Jul 5, 2004
    210
    28
    Fleet, Hants
    +26
    Yep. It sounds a tone and the light flashes green so I'm sure power is getting through.
    Thanks again
    Tommo
  10. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    I'm wondering if adding the UPS has prevented you seeing banding through EMI or RFI rather than VB on the LCD itself. Either way, it's better PQ!
    (do I get a prize for most acronyms in a sentence???)
  11. CooperUK
    CooperUK
    Jun 30, 2003
    2,166
    Hampshire
    +287
    I've just ordered a prog scan DVD player so that should improve things too :D
  12. RLT
    RLT
    Mar 28, 2005
    343
    +12
    As regards Tomooks UPS problem
    Had same trouble, but was advised to leave unit pluged in to mains to charge internal battery for 12 hrs before trying to switch on, as the onboard battery had been depleated since being manufactured, which led the self test on the ups think that the battery was "donald ducked"
  13. tommouk
    tommouk
    Jul 5, 2004
    210
    28
    Fleet, Hants
    +26
    Took it back and got a replacement. Tested replacement in shop, worked fine. :thumbsup: Haven't tried for VB yet (still charging)
    Tommo
  14. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    No way I work in IT and your TLA count was rather low. I'm used to TLAs filling my day along with the infamous GTTLAs :devil:
  15. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    How much power does your projector take ? That things only rated at 225 Watts ! :eek:
    Hope you have a fire extinguisher ready :D
    One of these may have done the job better (bigger and heavier, though).
