Question UPS for PS4 pro?
Discussion in 'Playstation Forums' started by luv2rocku, Jul 19, 2018.
  1. luv2rocku
    luv2rocku
    Aug 3, 2008
    38
    karachi
    Looking for a pure sine wave ups only for PS4 pro, APC i heard is the best but someone please give me link which model is best for only ps4 pro.
  2. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,271
    +1,895
    I would challenge the need for a pure sign APC for any equipment with a switched mode power supply. For equipment with linear power supplies, then yes, pure sine is important, but modified sine (Basically a triangle wave) causes no issues for SM PSUs and is usually deployed in data centres.
    You need to decide how long you need the UPS to keep the PS4 alive for. Even a basic unit will probably run it for 15 minutes or so. I doubt you could configure a smart UPS to shut down a PS4 in the same way it will a server or PC, but I don't have any specific knowledge of this.
  3. luv2rocku
    luv2rocku
    Aug 3, 2008
    38
    karachi
    I need only 5 to 10mins backup to shutdown ps4 properly if it is not shutdown properly then my hdd become corrupted sooner or later... already lost all the data because of sudden electricity shutdown in my area.
  4. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,271
    +1,895
    Do you need to keep your TV / Monitor alive while you power down the PS4?
    If so look at a 1000VA unit, but otherwise 600VA is more than enough.
    1VA is about 0.85W, so if you multiply up the power required by the TV and PS4, you can work out the minimum requirement. I would then add about 30%, as this will give you extra battery stay alive life.
  5. hippo99
    hippo99
    Feb 29, 2008
    17,191
    163
    +10,324
    Worth considering getting PS+ as well so you can have cloud backups of your save data.
