Green Tentacle
Hi. I'm looking to upgrade my humble 5.1 system on the cheap.
I'm using some Wharfedale 9.0s (the smaller bookshelves) as fronts, some old Sony hifi speakers as rears, a repurposed Boston Acoustics sub and a (pretty poor) Yamaha centre speaker that came with the receiver. The receiver is a basic 2000s Yamaha one via optical.
My upgrade route will likely be centre -> fronts -> sub -> receiver. I'll likely be happy repurposing the 9.0s as rears long-term.
So my questions are:
1. Is this the best upgrade route?
2. If so, what would you recommend for a centre? The matching Wharfedale centres are hard to find, and seem overpriced to me. I like the look of the Qacoustics 3090C which is £80 at Richer Sounds.
Any help is hugely appreciated
