Uprade for my Denon 3800
Discussion in 'Blu-ray & DVD Players & Recorders' started by eyerish, Aug 26, 2003.
  1. eyerish
    eyerish
    Hello there... a quick question for anyone that can help me. Is there a posability of upgrading my denon 3800 to play SACD via a software mod. What exactly can I achieve with the rs232 port on the back of it. I`d like to personalize the machine a bit ie. wallpaper, etc. Grateful for any help. Cheers!
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    no luck for SACD within software alone, this is will need to be a hardware change and quite a major one at that - only route to SACD is to buy 2900 or wait for the replacement to 3800 with SACD (think this is the 5900???)
    Check out the following for RS232 info:
    http://www.usa.denon.com/catalog/pdfs/CONTROL PROTOCOL DVD9000_3800 Ver.1.0.pdf
    JJ
    P.S. check out my site for other 3800 info ;)
  3. eyerish
    eyerish
    thanks for the advice jasonjo. I`ll check out the links u passed on tonight. Cheers..
