UPnp-Not Available
Discussion in 'Playstation Forums' started by wibbers9, Apr 30, 2007.
  1. wibbers9
    wibbers9
    Apr 25, 2007
    477
    +21
    Could anybody help?:lease:
    When i do a Test connection the following appears:
    Obtain IP Address Succeeded
    Internet Connection Succeeded
    PLATSTION Network Succeeded
    UPnP NOT Available
    NAT Type Type 2
    Does this mean i cant use a headset online, as i'm struggling to set mine up?
    I've tried to do a Manual set up, but i don't know what settings to enter in the following fields:
    Default router
    Primary DNS
    Secondary DNS
    I'm on Orange broadband, if that helps?
  2. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    hi there, before i got my wirless router mine was saying that bu the headset was working! What type of headset are you using?
  3. wibbers9
    wibbers9
    Apr 25, 2007
    477
    +21
    And old Jabra Bt200 which i had for my mobile phone:mad:
  4. wibbers9
    wibbers9
    Apr 25, 2007
    477
    +21
    And my Ps3 is connected wired, not wirless- if that makes a difference?
  5. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    NAT Type 2 (or 1) is fine. The nonworking one is NAT Type 3.
