Upgrading VGA -> VGA lead
Discussion in 'Plasma TVs Forum' started by robbleiper, Feb 20, 2005.
  1. robbleiper
    robbleiper
    Dec 31, 2004
    1,005
    Newport-on-Tay
    +37
    Have just ordered new scarts to connect dvd/sky to JS vga Box. Was wondering if anyone can recommend a good VGA lead to connect from this to my PWD6????
  2. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    Bettercables Silver Serpent is the one that I am recommending.
  3. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    robbleiper
    I got sent a bog standard cable from Avsales with my PW7, but part of the deal was a hand made Van damme VGA cable.
    So i used the bog standard one for a week then switched over once avsales had posted out the correct cable...........................couldn't notice any diff to my eyes.....................quite expensive too.
    But might have always wondered if i could get better PQ if i'd used the standard.
    Cheers,Tam
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I've never been convinced that expensive cables are worth the money over short distances...for longer lengths then they can show their value...that said I have bought decent cables throughout just to be sure.
    I doubt you'll find better than the Bettercables Silver Serpent range but it could cost as much as your converter did...if not more...Van Damme are also good and a fair bit cheaper to boot.
    Cheers, Lee
  5. Remboy
    Remboy
    I have an unwanted brand new 1 metre Van Damme VGA to VGA cable purchased from av-sales which I can sell you in the clasifieds if you're interested? Either way, personally I always buy "medium" quality cables not the cheapo ones, say around £50 per cable. In my experience, not convinced the premium ones really make any difference and certainly not enough to justify the extra cost.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    is this in teh classifieds already?
  7. Remboy
    Remboy
    No will put in now if you like?
  8. Remboy
    Remboy
    mep - added cable to my existing classified ad.
  9. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    thanks mate will take a look
